Anamorphic SD 16:9?
Hunter Julius
Anamorphic SD 16:9?
on Apr 30, 2012 at 1:17:59 am
This is probably a really dumb question, but...
I work for a church where we capture live footage from a video switcher with software. The video is shot in HD 1440X1080. We captured it to 720X486 which looks good but it has the horizontal black bars on top and bottom.
I need to end up with anamorphic 480p if possible, so that the video dimensions are widescreen with no black bars and would fill a widescreen window. Is it 720X405? How do I cut out the black bars and retain the quality?
Michael Gissing
Re: Anamorphic SD 16:9?
on Apr 30, 2012 at 5:24:31 am
The question is how you captured it. What is doing the downconvert to SD? That is the step where pixel aspect must be changed to be anamorphic. Although 1440 x 1080 is also using an anamorphic technique, scaling down to SD needs to have anamorphic defined.
© 2018 All Rights Reserved
