ProRes HQ export to MXF
Peter Stoel
on Apr 29, 2012 at 1:46:10 pm
I know how to export via xdcam transfer, but if the file is 1920 and I want to export to a SD MXF, how come it's so quick? I'm wondering how I get the highest quality SD iMX via xdcam transfer to MXF?
Bouke Vahl
Re: ProRes HQ export to MXF
on Apr 29, 2012 at 2:53:44 pm
If it is very quick, you suspect the downconversion to be bad?
I'm not sure what part of the entire chain does the downconvert, but you could try putting your HD movie in an IMX sd project, and render to a simple codec, see if you get the same speed.
Otherwise, pick any app. you like to do a good downconversion, put that in an SD project and export...
But, did you look at the outputfile on a CRT? Does that look right?
(I hate the look of SD on my gorgeous expensive HD monitor and switch back to a good old CRT when i can...)
smart tools for video pros
© 2018 All Rights Reserved
