Audio Tracks Locked Together?
Jim Murphy
on Apr 28, 2012 at 5:01:52 pm
OK. So I tried to find an answer for this but came up empty.
Working on a project where I want to duplicate the right track to replace an audio issue on the left track... I cannot select an individual track (I am trying to select the right channel of a stereo audio track). Every time I try and select it it automatically selects both the left and the right. I tried locking the left track to try and individually select the right but when I do that FC tell me that I cannot because one of the tracks is locked. The left and the right tracks seemed to be glued together. How can I "unglue" them?
I tried to open the track up in Soundtrack but when I got there I couldn't do anything there either (couldn't use the blade tool, or even edit the tracks at all but that's another question completely).
I probably am missing something obvious here. Can anyone shed some light on this?
Jerry Hofmann
Re: Audio Tracks Locked Together?
on Apr 28, 2012 at 8:41:29 pm
Select both tracks, then turn off stereo pair in the modify menu.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Jim Murphy
on Apr 28, 2012 at 9:12:15 pm
You are a lifesaver. Simple when you know. hehehehe.
Jim Murphy
on Apr 28, 2012 at 9:12:36 pm
Maybe you can also explain why I could edit the tracks in Soundtrack?
Jerry Hofmann
on Apr 29, 2012 at 1:38:22 pm
Pretty simple... they aren't locked as a stereo pair.
Jerry
Current DVD:
