h264 export problems
margarita kouvatsou
on Apr 26, 2012 at 5:11:32 pm
dear all,
I am working on a 1920 x 1080 progressive sequence with apple prores material.
I am facing the following problem: every time I export my footage with quicktime compression to a h264 codec and raise the contrast I get some kind of weird white or magenta flashes in some parts of my exported video.
Any idea what might be causing that as well as suggestions on how i can eliminate the problem?
all help appreciated!
thanxs is advance!
Dave LaRonde
Re: h264 export problems
on Apr 26, 2012 at 5:55:38 pm
Don't export to H.264 from the FCP timeline. Instead, export a self-contained quicktime movie. Then you have the option of using either QT Pro or Compressor. You have more control in Compressor.
Dave LaRonde
Sr. Promotion Producer
