light strikes effect
Giuliano Bausano
on Apr 24, 2012 at 2:25:02 pm
Hi everyone,
do someone of you know how to do this kind of video lens light strike effect, please?
Dave LaRonde
Re: light strikes effect
on Apr 24, 2012 at 4:27:36 pm
It's called a Lens Flare, and I believe it can be done in Motion. I know for a fact that it can be done in After Effects.
Other people will have other suggestions for making it.
Dave LaRonde
Sr. Promotion Producer
Jeff Meyer
on Apr 24, 2012 at 4:52:40 pm
Motion has a lens flare generator, but it's pretty basic. For the look you're wanting, the built in lens flare generator won't cut it. If I remember correctly it doesn't even have transparency, so you'll need to use composite modes or a luma keyer to have it appear over the video. Also, if you do go with the built-in generator make sure you animate the lens flare's origin, not its x/y position.
This Motion plugin appears up to the task, but I haven't used it.
http://www.motionvfx.com/mplugs-1.html
If you have After Effects I can give a strong recommendation to Video CoPilot's Optical Flares plugin.
https://www.videocopilot.net/products/opticalflares/
Giuliano Bausano
on Apr 24, 2012 at 6:09:07 pm
thanks a lot for the answers,
i tought it was optical flares in AEFX but i supposed there is a plug-in which "pump" the light i already got in the scene..
lens flare gave me different results and, also, had to be animated :)
Giuliano.
