Changing source file audio
Joe Skibinski
on Apr 19, 2012 at 3:28:53 pm
I've already edited my video and it turns out the audio we have is bad. We have other audio that sounds better that we want to use, is there a way to change the audio without having to re-edit the whole video? Thanks
Tina Hedegaard
Re: Changing source file audio
on Apr 21, 2012 at 4:04:10 pm
I don't know the size of your project, but one solution could be to start a new project, import video and audio, sync, batch export everything.
Then in your project with the edited sequence reconnect to the new batch.
If your project is very large this can be very time consuming- I mean to batch export. Then I would probably manually change the audio, when you have the synced clips.
Yours Sincerely
Tina Hedegaard
Editor | Final Cut Pro 7 | Media Composer 5.0 -5.5
Mac OS 10.6.7
