Missing Codecs - FCP 6
grace raso
on Apr 17, 2012 at 10:03:17 pm
I'm working with a producer who is on FCP 7, and ingested the footage using ProRes LT. I'm still on FCP 6.0.6
We read a work around where you can just copy the QT codec for LT into your Library / Quicktime folder and it will work! Previously I could view the footage in FCP but couldn't create a SEQ with the LT codec.
I noticed that there is no Library / Quicktime folder - (I'm on FCP 6.0.6 , OS 10.5.8) - so I created one, and put in the codec file. Then FCP couldn't read to video files , period! Before I could at least view them... So I deleted the Library / Quicktime folder - thinking it could go back to the way it was - NOPE!
Then , even worse, other codecs from FCP were gone! I opened a different project - all that footage is XDcam codec, and that couldn't be read either. So basically I hosed all of my FCP codecs...
I've read a few threads about this - and mostly people tried to re-install FCP, and if that didn't work, the OS. But I am mostly left wondering - where does FCP 6 hide those QT codecs, if not in the Library / Quicktime folder. They must be somewhere, and if I can find that, perhaps can repair the damage I've done.
thank you!
Grace
