Render bar red even though codecs are the same
D'Arcy MacLean
on Apr 15, 2012 at 3:36:07 pm
Hello,
Apologies if this question has already been asked.
I've transcoded a bunch of H.264 footage to Apple Pro Res (proxy) to edit with in FCP 7. I've then created a new sequence and added a shot to the sequence and selected yes when it prompts me about matching sequence settings to clip settings. However, it is still giving me a red render bar. Is there something I'm missing here?
Thanks in advance for your help.
Cheers,
D'Arcy
Michael Gissing
Re: Render bar red even though codecs are the same
on Apr 15, 2012 at 4:11:44 pm
How did you do the transcode from H264? Is it Log & Transfer?
What are your clip settings and sequence settings, specifically frame size, fields etc?
D'Arcy MacLean
on Apr 15, 2012 at 4:25:22 pm
Hi, thank you for responding.
I used MPEG Streamclip
Clip settings and sequence settings are both:
Apple ProRes 422 (Proxy)
Frame size 1920x1080
Square pixels
Upper (Odd) field dominance
25 fps
Cheers,
D'Arcy
Michael Gissing
on Apr 15, 2012 at 5:08:47 pm
Depending on the source of the H264 files, they may be progressive. DSLR camera shoot progressive so although FCP thinks it is upper, it may be that the sequence setting should actually be progressive (or none in field setting).
Otherwise frame sizes are standard so I am surprised that you are getting render bars.
D'Arcy MacLean
on Apr 15, 2012 at 5:16:12 pm
The footage did come from a DSLR, but I've tried changing the field dominance of the clip and sequence to none, but to no avail. I've also tried changing the clip to none, then cutting into a fresh sequence to have it prompt match sequence with clip settings, but again nothing.
Thanks anyhow,
D'Arcy
D'Arcy MacLean
on Apr 15, 2012 at 5:32:42 pm
I think I may have solved it. In the export dialogue for MPEG Streamclip, there's a box that says Interlaced Scaling, and above it it says 'Deselect for progressive movies. Did a test and with said boxed unticked and it's working. The odd thing though is for my rushes, all the footage from the first two days were giving me the render issue whereas the last two days were fine (just noticed that after your last response). I had batched transcoded them all together so don't know why there was a discrepancy.
Regardless, unticking the box for the first two days rushes looks like it works so I can move forward.
Thanks for your time,
D'Arcy
Michael Gissing
on Apr 15, 2012 at 11:39:34 pm
Happy to help. I have struck the interlaced progressive thing before with DSLR footage. Personally I prefer to use Log & Transfer as it firstly gets this sort of thing right and most importantly it allows for an offline online workflow as it reads time data in the file and creates both a reel number and timecode so a Media Managed reingest at full res is possible.
If you have'nt already done so check Shane Ross's two excellent tutorials on tapeless workflows and offline/online with L&T.
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
http://library.creativecow.net/ross_shane/tapeless_online/1
