Exporting a Video Clip for Powerpoint Presentation on a PC
Jocelyn Hassenfeld
on Apr 12, 2012 at 3:06:25 pm
I'm working in Final Cut Pro 7.03.
I have a clip that less than 2 minutes that I need to export to play in a Powerpoint presentation on a PC.
The sequence is set as - Apple Pro Res 422
I understand WMV might be the right format but I can't find this setting in any of my compressing software - I have Compressor and MPEG Streamclip.
What format do you recommend I use and what step should I take to create it?
Thank you for your help!!
Jocelyn
Dave LaRonde
Re: Exporting a Video Clip for Powerpoint Presentation on a PC
on Apr 12, 2012 at 4:17:46 pm
You should:
1) Find out from the people actually doing the Powerpoint what kind of files they need. They should be able to describe them by right-clicking on a file that currently works, selecting Properties, and writing down all the information.
2) Probably purchase Flip4Mac to do the transcoding to Windows-centric media.
Dave LaRonde
Sr. Promotion Producer
Jocelyn Hassenfeld
on Apr 13, 2012 at 1:02:31 am
Thank you!
j
Mark Suszko
on Apr 13, 2012 at 2:10:03 pm
You might find a WMV setting if you go Export>using Quicktime conversion, but unless you paid the extra money (I think around 50 bucks) to unlock the full version of the encoder, you will only get 30 seconds rendered.
