ProRes export changing YCbCr to RGB... WHY??
Rachel Hayes
on Apr 12, 2012 at 1:01:01 pm
Hello,
I've got a client that has come in requesting a file at specs that I can't seem to set/find/provide.
I need to export a 1920x1080, 10bit Apple ProRes HQ file with YCbCr color space and 4:4:4 sampling, but every method that I've tried when exporting this file seems to fail and my file is changed from YCrCb to RGB.
I've tried exporting in Final Cut, Compressor and I've tried going through Premier and After Effects and every one of them changes the file to RGB. I'm going crazy.
This is a tech spec provided by the broadcaster so I have to provide exactly this. Any ideas??? Is there a plugin that I'm missing or a setting that's off??
Rachel
