Can't find an answer to this: HDV returned from DaVinci as progressive...
Seth Thy
on Apr 12, 2012 at 9:29:17 am
I can't find solution for this...
HDV 1080i50 / 1440x1080 / upper field edited in FCP, sent to DaVinci, returned as Apple ProRes HQ 1980 x 1080 / none field.
Picture in both projects looks ok on broadcast monitor.
That was all done before me.
The problem started when I tried to make mpeg2 / progressive for Digital TV. I tried sent it directly from FCP to Compressor and also tried to make reference file and import to Compressor - and result is the same: huuuge fields problem! First on my computer monitor, which surprised me since file should have been progressive. And than I imported mpeg2 file in FCP and same result was on broadcast monitor.
Same thing happened when I tried to make PAL DVD - Compressor / DVD Best Quality 90 minutes, authored in DVD SP.
I don't know what am I doing wrong...
