23.98 Sequence won't recognize 5D footage pasted from a 29.97 sequence
David Powell
on Apr 7, 2012 at 2:50:30 am
So in editing a project, I split it into 4 sequences. Somehow or another one of the sequences was not set right. It was set to 29.97. In the end, I tried to paste it into a 23.98 sequence and it won't recognize. All the footage is 23.98 from 5d Basically some clips disappear, go out of sync or/and turn green and flicker.
I tried rendering out to a quicktime and bringing that in, and had the same results. I get sound and no picture. What do I do now?
Bret Williams
Re: 23.98 Sequence won't recognize 5D footage pasted from a 29.97 sequence
on Apr 7, 2012 at 3:22:41 am
When you say 5D footage you mean ProRes right? if you're using h264 from the Canon directly then all bets are off. Anything can happen.
David Powell
on Apr 7, 2012 at 3:32:41 am
Yes. Pro res LT.
Joseph Hung
on Apr 9, 2012 at 10:46:20 pm
Can't you go back to that original sequence and change the settings, rerender, and maybe even output and bring it back in?
This is also assuming that you shot all of your footage at the desired settings, and the footage was also transcoded to the same settings... if all is correct, you could try copying the sequence and pasting it into a new sequence with the correct settings. If you shot the footage in the wrong settings, you'll have to use Cinema Tools to change the framerate and start over. Or do it to the output and see if your footage is okay.
http://www.tulpapictures.com
Twitter: @tulpapictures
Facebook: http://www.facebook.com/tulpapictures
Mac 2.66 GHz Quad Intel Xeon
OSX 10.6.8
FCS2
CS5
8GB RAM
ProAvio 8TB RAID 5 Dual Mini-SAS
Blackmagic Intensity Pro
ATI Radeon X1900
RocketRAID 4322 via dual MiniSAS
Panasonic Lumix GH2, Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
