Changing sequence settings for editing?
brad hebert
on Apr 6, 2012 at 10:35:06 pm
I'm familiar with offline editing, where the video files are smaller with matching sequence and then reconnect the hi-res footage later. But I'm curious if it's ok to simply change the sequence setting, in my case from ProRes to HDV, in order to render faster while I'm editing, and then change the sequence back to ProRes and re-render for final output. Will that cause any problems? I'm staying 1080p/24, but just changing the codec. Also, there is chroma keying involved.
Steve Eisen
Re: Changing sequence settings for editing?
on Apr 7, 2012 at 2:13:32 am
I would not recommend what you want to achieve. I would recomend ProRes the whole time. HDV is very processor intense due to its Long GOP codec.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Shane Ross
on Apr 7, 2012 at 5:04:03 am
Agreed. Rendering is ProRes gives better results, and should be quicker.
Shane
Little Frog Post
brad hebert
on Apr 8, 2012 at 3:22:17 am
Thanks for the info. I'm also curious:
If my main sequence and footage is 1080 ProRes HQ (mainly because of green screen), but I have other low-quality home-footage to add. Can the home footage be 480p ProRes LT to save space? Or should it be converted to 1080 HQ?
Dave LaRonde
on Apr 9, 2012 at 3:10:01 pm
[brad hebert] "Also, there is chroma keying involved."
When you chroma key lower-resolution footage, you will almost always have to readjust the settings if you reconnect to higher-resolution footage. You would be duplicating your effort.
Dave LaRonde
Sr. Promotion Producer
