29.97fps to 24fps
Julie Esris
29.97fps to 24fps
on Apr 6, 2012 at 1:43:27 am
I shot a video on Mini DV at the usual 29.97 fps. I want to convert it to 24 fps so it will look more "film like." After I do post production, I want to, of course, convert it back to 29.97 (but obviously just for DVD production; it would still have the 24 fps look). Can somebody please help me with this and tell me what to do?
Thanks so much!
Julie
Shane Ross
Re: 29.97fps to 24fps
on Apr 6, 2012 at 3:13:48 am
No no no no...you don't want to do that. You don't want to convert 29.97 footage to 23.98 and back again. That will look HORRIBLE. No no. If you want the 24fps look, you either shoot it that way, or use really good plugins designed to make it look that way.
FILM EFFECTS by nattress.com:
http://nattress.com/?q=FilmEffect%20
Shane
Little Frog Post
Julie Esris
on Apr 6, 2012 at 3:15:01 am
Are there any good ways to do this? Or should I just forget it?
Shane Ross
on Apr 6, 2012 at 4:58:03 am
There is. And I linked you to the plugin that would be your best option.
Shane
Little Frog Post
Julie Esris
on Apr 6, 2012 at 5:00:17 am
Julie Esris
on Apr 6, 2012 at 4:49:11 pm
How do I set this up once I've downloaded it??? There are no instructions.
Shane Ross
on Apr 6, 2012 at 5:03:58 pm
Is there no installer? If there is an installer that will put it into the plugins folder. Then launch FCP and it is in the FILTERS.
Then the using and tweaking of it is up to you. For the 24p look, you apply the G FILM effect.
Here's a tutorial on the color options for the set
http://www.glennchan.info/video/FCP/nattress_tutorial2.htm
Shane
Little Frog Post
Julie Esris
on Apr 6, 2012 at 5:05:00 pm
It is only a text file.
Shane Ross
on Apr 6, 2012 at 5:14:32 pm
Hey...so it is. It's a .sit file...needs to be uncompressed...unzipped.
You need Stuffit Expander to unzip this. Free found here: http://www.stuffit.com/mac-expander.html
Shane
Little Frog Post
Julie Esris
on Apr 6, 2012 at 5:24:52 pm
Ah ha! Thanks. Anyway have you tried this plugin? How does it do with the deinterlacing etc. when converting to 24fps?
Shane Ross
on Apr 6, 2012 at 5:35:19 pm
OH YES...I used it all the time when I was working with DV footage. Not so much anymore, as we can shoot 24fps. But when it wasn't possible, I used it all the time. Deinterlaces and all
Shane
Little Frog Post
Julie Esris
on Apr 6, 2012 at 5:36:33 pm
Thanks so much!
Jerry Hofmann
on Apr 6, 2012 at 5:36:58 pm
Grame's stuff always does a great job for the money especially...
Download the demo... it's free and decide for yourself if the filter gives you the look your after.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Julie Esris
on Apr 6, 2012 at 5:41:09 pm
Which "G Film" specifically? There are a lot of them.
Shane Ross
on Apr 6, 2012 at 6:47:54 pm
Play around. That's how I figured things out.
Shane
Little Frog Post
