Anyone used sayqua.com XML subtitle file creator
Ben Edwards
on Apr 3, 2012 at 9:38:03 am
We are getting rushes translated by an agency and I found sayqua which looks like a great way to get get the translations into FCP. Has anyone used this.
My big question is should I use the timecode reader (to generate timecodes from the clip/camera)) or generator (to generate timecodes relating to the timeline) to create burnt in timescodes for the agency.
Ben
Ben Edwards - Freelance Picture Editor
http://www.funkytwig.com
Macpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
Srimonti Karmakar
Re: Anyone used sayqua.com XML subtitle file creator
on Apr 3, 2012 at 1:59:18 pm
Hi Ben,
I replied to your email; posting here for reference.
You can use the timecodes from the timecode reader.
Just make sure when you use sayqua, "Adjust for drop frame" is selected (in the Settings part) if you are working with 29.97 or 59.94 fps. It is selected by default. This ensures when you import the sequence of subtitles (the output of sayqua), the timecodes of the subtitles align with the timecodes assigned by FCP to your video clip.
~ Srimonti
Srimonti Karmakar
http://sayqua.com
