File size changes when I copy/paste a timeline to a new sequence
Cassie Chappell
on Mar 31, 2012 at 6:44:26 pm
The header says it all: I copied a timeline from one sequence & pasted it to a new sequence. Sadly, the file sizes are greatly reduced from the original. Any input is welcome... thank you!
Jessica Pic
Re: File size changes when I copy/paste a timeline to a new sequence
on Mar 31, 2012 at 7:54:52 pm
When you paste into the other sequence, select each part of the timeline so that its highlighted (each clip that needs to be fixed) and go up to Modify in the top bar and select "Conform to sequence."
That should fix it.
