Audio disappears after merging in fcp6, after using Wave Agent to synch with dslr footage
David Thompson
on Mar 29, 2012 at 3:55:43 pm
Help!
I just used wave agent for the first time to prevent audio drift with my dslr footage. I imported it fine in to fcp6 and after merging audio and video, I try and drag it in to the timeline. As the newly merged footage hangs over the time line, I can side the perspective shadow of 4 audio tracks, then when I drop it in the timeline, only 2 are there (the originally crappy sound from the camera).
Have played about with it and am going totally crazy as I have never come across this before. Normally merging my clips works fine, the only different thing I have done to these files is put them through wave agent. I can play all clips independently fine, it's just when I merge them, tracks 3 & 4 disappear when i drop them in the timeline.
Anyone have any suggestions?? I just can't figure it out and have looked around online so long I can't find anything on it.
Many thanks,
Dave
Dave LaRonde
Re: Audio disappears after merging in fcp6, after using Wave Agent to synch with dslr footage
on Mar 29, 2012 at 8:21:44 pm
You didn't mention a crucial bit of information: the codec of the footage.
If it is still in the acquisition codec of your DSLR -- in which case it's probably H.264 -- I regret to inform you that your video clips could very well be the source of your woes.
H.264 is not a valid editing codec for FCP. Your best bet would be to transcode them to ProRes 422 and start over from scratch with Wave Agent.
Dave LaRonde
Sr. Promotion Producer
David Thompson
on Mar 29, 2012 at 9:36:12 pm
Hey Dave,
Thanks for your message. Yep I've converted it already to Pro res through Magic Bullet grinder... I just can't figure it out
Michael Gissing
on Mar 29, 2012 at 11:06:34 pm
If you are using wave agent to correct a 'feature/bug' in FCP of audio drift then you are chasing problems.
Matt Lyon's tutorial explains how and why FCP incorrectly stamps a frame rate on imported audio assets and how to fix them via XML or later in the tutorial, he explains how to import audio correctly to avoid the mistake.
http://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
