AE D1 Widescreen QTs not importing w/correct aspect ratio in FCP CCIR 601 NTSC 40:27 sequence
Billy Spence Jr
on Mar 28, 2012 at 10:02:56 pm
Tried multiple times to render out an After Effects NTSC Quicktime in Animation codec that will import into FCP with the correct 16:9 aspect ratio. AE comp settings are NTSC D1 Widescreen with a pixel aspect ratio set at D1/DV NTSC Widescreen(1.21). Final Cut Pro sequence setting is CCIR 601 NTSC 40:27. Unsure how to correct this. Please advise. Thanks!
Andy Murphy
Re: AE D1 Widescreen QTs not importing w/correct aspect ratio in FCP CCIR 601 NTSC 40:27 sequence
on Dec 12, 2012 at 2:20:58 pm
I am having this same issue. Did this ever get resolved? Thanks.
