Apply flash effect in Wide Screen
Daniel Neutzsky-Wulff
on Mar 28, 2012 at 2:27:15 pm
I'm editing a trailer where I use some camera-flash effects. Using dip to color.
However, it affects the ENTIRE screen, the black bars at the top and bottom since it's widescreen. I won't the flash effect ONLY to affect the picture itself not the black bars above and below.
How do?
Thanks in advance,
Daniel
Juan Manuel
Re: Apply flash effect in Wide Screen
on Mar 28, 2012 at 2:51:38 pm
Well, you can use a four point garbage matte to mask only the relevant part, but why are you using black bars to begin with? Just use a widescreen sequence
Dennis Leppell
on Mar 28, 2012 at 3:28:23 pm
use the Too Much Too Soon flash frame transition plugin found here:
http://www.mattias.nu/plugins/
I also REALLY like the Impact flash found here:
http://www.filmimpact.net/index.php/plugins/
And yes, use a sequence that matches your footage dimensions.
on Mar 28, 2012 at 4:06:17 pm
All the material was converted to:
Apple ProRes (HQ), 1.280 x 720
Linear PCM, 32 bit big endian signed
integer, 48000 Hz, Mono
Sequence settings:
1280 x 720 (Aspect Ratio HDTV 720p (16:9)
Apple ProRess 422 (HQ)
Those are my settings at the moment, I still get the black bars in the top and bottom,
what am I doing wrong?
Also, do you know any other plugins good for a horror trailer?
Like inverted flashes and stuff?
I know these are possible with the effects already built in, but the transitions you linked were pretty good.
Rafael Amador
on Mar 28, 2012 at 4:15:10 pm
[Daniel Neutzsky-Wulff] "Those are my settings at the moment, I still get the black bars in the top and bottom,
what am I doing wrong?"
Select the footage in the time-line, and "Remove attributes: Basic motion + Distort.
rafael
http://www.nagavideo.com
