wav export: FCP audio tracks get sent to Soundtrack Pro at full length??
grover sald
on Mar 26, 2012 at 1:06:26 am
I have some long AV files that I am processing into a set of 1-second-long excerpts. I've already imported the long source file into FCP as a project, and the short excerpts have also been saved as separate projects. One step requires manipulating the audio track of each 1-second excerpt, so I am trying to send each excerpt's audio track into Soundtrack Pro, in order to save it from there as a wav file. But when I "send to" Soundtrack Pro, the entire source audio track copies over, not just the one second excerpt. I did similar work a year ago without trouble, so I'm wondering if there's a setting somewhere I've forgotten about. Thanks for any help!
