Compressor Droplets: New Folder as part of Filename Template???
Eddie Adams
on Mar 25, 2012 at 9:10:39 pm
What I'm trying to do is set my Compressor Droplet as such:
Destination = Source
Filename = /New Folder/[Source]
The goal is to be able to drop the files, and have them re-encode and output as the EXACT filename as the original, but in a New Folder within the Source directory (I'm creating Proxy files which I will eventually replace with Originals for the online edits).
When I try to run the droplet as stated above, I get the error: The output “MVI_2982” can not be saved in “New Folder” because you do not have appropriate access privileges. To view or change access privileges, select the item in Finder and choose File > Get Info.
Is this even possible? I'm hoping for a completely automated droplet, where I won't have to select the Destination each time. Any ideas? Thanks.
