Re-Render Issues
Jim Murphy
Re-Render Issues
on Mar 23, 2012 at 6:22:36 pm
So I'm working in a project and have rendered all my sequences. At times, even after completely rendering the sequence and saving the project, once I click on it ant try to play it, it will require a re-render. What's going on???
Shane Ross
Re: Re-Render Issues
on Mar 23, 2012 at 6:51:30 pm
What footage are you working with? What codec? What are the sequence settings?
Shane
Little Frog Post
Jim Murphy
on Mar 24, 2012 at 2:38:30 pm
I actually discovered the issue... another editor working on the same project for some reason sent a project folder, with render files, to the trash and was replaced with an updated folder of the same project. FC seemed to be writing the render files to the Trash folder... can that be???
I retreived the Trashed folder, reconnnected and all was back to normal.
