Syncing dailies
John Christoforu
Syncing dailies
on Mar 22, 2012 at 8:18:11 pm
Hi, when I sync rushes, I always link audio to video. I create a new seq. and I sync slate and audio together.
Then I use cmd> L to link shots in case I go out of sync while editing. The problem is when I export an EDL for final grading no timecode or any other info is present. On the timeline clip names there is only the seq. name given when created. Do you have any Idea how I get this right? I had to double click on each shot on the time line and then the sync seq. comes up, then I click match frame, mark the clip and replace it. I'm sure their is a proper way doing this and I don't know how.
Regards John
Shane Ross
Re: Syncing dailies
on Mar 22, 2012 at 9:12:00 pm
Yeah, there is a proper way to do this. It's called MERGE CLIPS:
http://documentation.apple.com/en/finalcutpro/usermanual/index.html#chapter...
Shane
Little Frog Post
John Christoforu
Re: Syncing dailies
on Mar 23, 2012 at 7:13:01 am
Thank you Shane, really appreciated!
Antoine Vermeesch
Re: Syncing dailies
on Mar 23, 2012 at 1:59:57 pm
Sync-N-Link is also a very useful software
if your audio source TC match with the video
I'm using it on huge projects,..
