Multiclip only cuts with a mouse click
Mike Forbes
on Mar 21, 2012 at 11:24:16 pm
Straight to the point while using multiclip the only way I can get to cuts to work correctly is by mouse clicking the angle in the viewer. If i try using the viewer or the button bar they make the grey marker similar to when I click in the viewer but when i hit to space bar, instead of making the cuts the markers simply disappear and no cuts are made! I tried setting hot keys to switch the angles and I get the same results. any suggestions?
