5.1 Sound for Quicktime delivery
Erin Chan
on Mar 20, 2012 at 11:47:23 pm
Our distributor wants a QT master of a finished feature doc with 5.1 mix. I've done this with a 6 track 5.1 printmaster, but the sound mixer has delivered 30 5.1 tracks (L,R,C,LFE,Ls,Rs) each for the Comp, DX, FX, M&E, and MX. Sorry if this is a simple question, but how do I get these 30 tracks into a 6 track layout? I tried laying all the track in the FCP sequence and assigning the audio outputs to the correct tracks 1-6, and exporting a quicktime, but the LFE,Ls,Rs (tracks 4,5,6 in the exported quicktime) don't contain any audio. I also tried exporting by sending to Compressor and in that case tracks 5 and 6 did not have audio. What am I doing wrong? Your advice is greatly appreciated.
FCP 7.0
Shane Ross
Re: 5.1 Sound for Quicktime delivery
on Mar 21, 2012 at 12:10:05 am
This is something you need to do in Soundtrack Pro...or ProTools, or Logic. An Audio app...not video app.
Shane
Little Frog Post
Ken Conrad
on Mar 21, 2012 at 6:40:55 pm
So they did not give you a final 6 tracks with just the final mix? DX,FX, and M&E are for deliverables if they want to make changes later... I am not sure what the Comp and MX are.
Is there not one set that contains just the final mix?
you should not have to mix them nor would i think your mixer would want you to.. they are usually pretty picky about that
Erin Chan
on Mar 21, 2012 at 6:52:31 pm
Thanks, I got the 6 final 5.1 mix files from the sound guy so it's all good. Appreciate the replies.
Michael Gissing
on Mar 22, 2012 at 12:09:17 am
All the other audio deliverables should be on a DVDRom or external drive. For audio reversioning sound facilities want those files as wavs, not quicktimes so only the final mix should be in the video quicktime
