Need to extract extras
Jim Makichuk
on Mar 19, 2012 at 4:52:30 pm
Doing a 40's director proposal, need to extract trailer from 40's movie. Not sure how to do this exactly, I've used streamclip but not for extras.
Neil Patience
Re: Need to extract extras
on Mar 19, 2012 at 6:24:23 pm
Inside the TS folder there should be a VOB file for the extras content.
You would have to do a bit of trial and error to see which one to open but you should find it.
best wishes
Neil
http://www.patience.tv
Juan Manuel
on Mar 19, 2012 at 6:58:58 pm
If you have a PC around, or Windows running in your mac, you can use an old freeware called DVD Decrypter to extract just the extras
Jim Makichuk
on Mar 19, 2012 at 10:16:05 pm
Thanks all very simple too. One other thing, I'm going to edit a mix of HD 1080i and 4:3 DVD video and b&w stills. Not sure format should I use for final product to dvd? Seems like 16:9 would be one choice?
Neil Patience
on Mar 19, 2012 at 11:32:24 pm
Since you are questioning 16x9 or not for your DVD I assume you are considering editing this propsal film in Standard def.
That actually makes a lot of sense especially if viewing will be on a DVD and as the 4x3 DVD source will suffer like hell getting to HD only to be resized back to SD for a DVD looking much worse for the journey.
I would probably edit in SD 16x9 and then either pillarbox the 4x3 or zoom in to it if it looks like it can handle it quality wise.
Plug-ins like Neat Video could help you de-noise the DVD footage.
Hopefully you will get a commision and then go HD and hopefully get better source for your archive.
best wishes
Neil
