auto adding Keyframes in Color corrector
Steve Stephens
on Mar 18, 2012 at 9:51:14 pm
Trying to adjust a clip which involves a walk into and thru a building; from daylight to tungsten to fluorescent and back to daylight.
Had been using the 'add keyframe' technique as per
http://podcasts.creativecow.net/final-cut-studio-podcast/keyframing-color-c...
For a good couple of hours ad then for no reason I can find FCP7 starts adding smaller keyframes to the viewer timeline whenever I touch an adjustment slider.
I realise this is another way way to 'transition' the adjustment as the clips progresses BUT I cannot find the control which will allow me to just add keyframes where and when I want then.
Jerry Hofmann
Re: auto adding Keyframes in Color corrector
on Mar 19, 2012 at 1:10:06 am
Well... any time you make an adjustment after you've set the first keyframe in a clip, new keyframes are added at the position of the playhead. So don't adjust anything unless you are on a keyframe you've already set or you want to set one where the playhead sits. This is the built-in behavior of FCP's filters, and there's no setting to change to switch the behavior.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Steve Stephens
on Mar 19, 2012 at 9:48:17 am
Thank you.
It seemed to be behaving differently when we first used it but as we had just discovered it I guess it was all part of the learning curve!
