drop frame video and timecode display
Alexandre Brandt
on Mar 18, 2012 at 12:51:45 am
Hello all,
I have logged and transferred AVCHD footage to Apple ProRes 422(HQ). The format shows me 23.98 for the time code. My sequence is at 23.98. I noticed that my timecodes shows with hh:mm:ss:frame with a colon for "non drop frame" format and not a semicolon for drop frame formats which is the case for this 23.98 am I right ? Is there something I'm doing wrong ?
Thanks for your attention.
motion pictures + storytelling = ?
-> FILMMAKING !
Jerry Hofmann
Re: drop frame video and timecode display
on Mar 18, 2012 at 4:42:45 pm
AFAIK, the behavior you're seeing is normal... just as long as the frame rate is reported right, which, in your case it seems to be, you don't have a problem.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
John Christie
on Mar 18, 2012 at 5:40:25 pm
People often confuse frame rate with drop frame, assuming that 23.98 is drop frame and 24 is non drop frame. FCP doesn't provide 23.98 drop frame as a time code option. This isn't an issue unless you're formatting your shows for broadcast.
I once heard someone at a user group meeting say that he never shot drop frame because the pictures looked "stuttery" from all the dropped frames :)
Alexandre Brandt
on Mar 18, 2012 at 8:43:45 pm
ok
-> FILMMAKING !
Eric Keto
on Apr 1, 2015 at 6:21:04 pm
Hey John, I'm having the very problem you're referencing here, any idea what I should do if I am formatting my edit for broadcast? https://forums.creativecow.net/thread/344/36575#36599
