Film burn / Light Leak problem (Video link included)
Jim Elliott
on Mar 16, 2012 at 1:40:42 pm
Having some trouble adding light leaks in this sequence in final cut. I put several light leaks over the sequence but at the point of the leak clip starting (the leaks are set to 'screen' composite mode) the blacks seem to get darker. This is not a problem I've had before with other light leeks :s
- have a look at this to see the problem
Jim Elliott
Re: Film burn / Light Leak problem (Video link included)
on Mar 16, 2012 at 2:31:15 pm
Have also noticed that when i move the leak clip to a different track, it look fine BEFORE render (no colour change), but the colour/contrast change comes back again after render :-(
