Setting scratch disks
Sean Simms
on Mar 15, 2012 at 10:51:19 pm
Is there a way to set the scratch disks on one sweep?
That is, set all of them to them same drive at once without having to repeat the process 4 times?
Shane Ross
Re: Setting scratch disks
on Mar 15, 2012 at 11:04:31 pm
Why are you repeating the process 4 times? Do only the first line of options, and you are good. The other options are if you have MULTIPLE drives you want to use, and happen to turn one off.
Shane
Little Frog Post
Sean Simms
on Mar 16, 2012 at 9:58:52 pm
What about the waveform, thumbnail and autosave selections? I use a computer at school and put everything on my portable hard drive.
Sincerely,
Eros Salvatore
http://www.erossalvatore.com
