Issues With Syncing Audio
Greg Burke
on Mar 14, 2012 at 11:08:36 pm
Hey all I received about 120gigs in Mico SD Cards, all on the footage is 720p H.264 and all the audio (Witch is separate) is .wma.
I put all the videos in compressor to transcode them to proress and all the audio files to transcode to .aiff
I bring them into final cut and sync them up using my ears and eyes or plural eyes.
everything is fine at first but as the video plays the audio becomes more and more out of sync toward the end of the 3-4min clip the audio is about 4-5 seconds completely off. What could be causing this? is it FPS issue?
I wear many hats.
Shane Ross
Re: Issues With Syncing Audio
on Mar 14, 2012 at 11:58:35 pm
Was the audio recorded at 44.1Khz? Not 48Khz? Did you convert to 48Khz?
Little Frog Post
© 2018 All Rights Reserved
