Trying to Import and Edit 3D Footage shot on Sony HXR-NX3D1 NXCAM 3D
Kalen Rixon
on Mar 9, 2012 at 10:55:37 pm
Hello Everyone,
I'm trying to complete a project for a client; however, he threw me a curve ball and showed up with 3D footage, which I am not set up for currently.
He shot on the Sony HXR-NX3D1 NXCAM 3D. I need to know how to transcode this footage and edit it in Final Cut Pro 7.
Big Thanks to Anyone that can help me out.
-Kalen
Neil Patience
Re: Trying to Import and Edit 3D Footage shot on Sony HXR-NX3D1 NXCAM 3D
on Mar 9, 2012 at 11:22:33 pm
I was looking at this the other day for a client and what I have managed to work out is that the Sony HXR-NX3D1 records in MVC format which is essentially both left and right encoded into a single file.
I think you can only currently use Vegas 10 to edit it (which comes bundled with the camera)
(Unless someone has worked out a way to demux this footage to L+R)
If you can get it to left eye right eye (which is questionable) then you need a 3D plug in like http://www.onsight.co.uk/OS3D which is free.
or
http://www.dashwood3d.com/stereo3dtoolboxle.php which is $99
I have to say I have not used these plug ins - just passing on my pretty limited knowledge from looking at this myself the other day.
Hope it helps
best wishes
Neil
http://www.patience.tv
Shane Ross
on Mar 9, 2012 at 11:29:35 pm
Shane
Little Frog Post
Neil Patience
on Mar 10, 2012 at 3:03:34 am
Hi Shane
you provided the same link as me but as I understand it the MVP format that is used by that cameara is not compatible with the usual left eye right eye steroscopic files.
Does the Dashwood plug-in work ? I had read this discussion here where Tim Dashwood seems to suggest it does not but may have read it wrongly.
https://discussions.apple.com/thread/3159992?start=0&tstart=0
best wishes
Neil
Shane Ross
on Mar 10, 2012 at 3:33:28 am
I didn't research this camera and workflow as well as you. I'm sure Tim is right. And you might be right that only Sony's NLE will work with it. Very often people don't think about this when they buy cameras, and shoot. Post is always an afterthought. Well, to a few..
Shane
Little Frog Post
