size counts -- i.e. how to downscale proportionally
Steven Austin
on Mar 9, 2012 at 2:11:59 am
A client needs a 1920 x 1080 project scaled down to 1440 x 1080. To keep it proportionally correct, it sounds like a letterboxing technique... of which I am woefully uninformed. Does anyone have an easy-to-digest answer? ;) Thanks!
quad core tower
FCP 7
Jerry Hofmann
Re: size counts -- i.e. how to downscale proportionally
on Mar 9, 2012 at 2:51:32 am
No it doesn't sound like that... it sounds like HDV. It's still 1080 video when it is that size. The difference between it and 1920 is that the pixels aren't square. They are rectangular. i.e., 1080 HDV is 1440 X 1080.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Steven Austin
on Mar 9, 2012 at 3:05:27 am
So after I bring it into Compressor, what export settings do you suggest? After it's 1440 they want it all all manner of codecs, for phones & streaming, etc.
(This is the part where I start getting wistful about 35mm film... One size fits all!!!)
Thx
"In modern action films, the only people who work up a sweat are the editors." -- Roger Ebert
Shane Ross
on Mar 9, 2012 at 3:31:16 am
This is a case in which the clients are woefully misinformed. 1440x1080 is ANAMORPHIC HD...squeezed in order to save on data rate...file sizes. FCP and other NLE's will stretch the image out so you see it as if it were 1920x1080...the full dimensions of HD. 1440x1080 would be 4:3 HD, and that doesn't really exist. 1920x1080 is the proper dimensions for HD. Unless the devices they are outputting to will only display 4:3. IN which case you'd be cropping off the sides...cutting them off. Not letterboxing.
Shane
Little Frog Post
Steven Austin
on Mar 9, 2012 at 3:39:51 am
Thanks...
Michael Gissing
on Mar 9, 2012 at 4:37:01 am
"(This is the part where I start getting wistful about 35mm film... One size fits all!!!)"
4 perf or 2 perf?
