Transition 'transform effect'
Timo Millitz
on Mar 8, 2012 at 2:12:23 pm
I'm looking for a way to create a transition with so I called a 'transform effect'. This can be seen in many music videos, for example like Michael Jacksons Scream (check 0:49, 1:11, 1:30, ...).
Can someone tell me how to do this? Is this possible with the default transitions/effects in FCP or do I need some special plug-ins?
Thanks a lot!
Timo!
Neil Patience
Re: Transition 'transform effect'
on Mar 8, 2012 at 2:36:12 pm
That is called a 'Morph' There are plug-in for FCP that do it although not sure if there is a free one.
Example of the kind of thing you need here. http://www.chv-plugins.com/cms/FxPlug/Morphing/Morphing.php?navanchor=10100...
Avid MC has this effect as standard called Fluid Morph
best wishes
Neil
http://www.patience.tv
