FCP X XML to FCP 7
Matt Ryan
FCP X XML to FCP 7
on Mar 8, 2012 at 10:24:24 am
Hi All,
I wonder if anyone has encountered this problem before. I'm using FCP 7 and I'm working with a translator providing me with subtitles in FCP X. The translator uses 18pt Helvetica for the text then exports an XML.
To get the XML into FCP 7 I use Xto7. But... when I import the converted XML I get 64pt outlined Lucidia Grande.
I thought I could counter this by using Title Exchange Pro, using an XML template to change the font size. However, after specifiying the input XML and the output XML sequence, TEP just gets stuck, with a message box saying "Loading".
I know I can try and edit the XML directly but I'd rather avoid this to save time and reduce the risk of errors.
Any insights very much appreciated.
Thanks very much,
Matt
