Adding random frames when I export from Final Cut Pro 7
Ranya Dube
on Mar 6, 2012 at 1:43:13 pm
Hi
I'm trying to export a sequence for Vimeo (using their required settings) which I made mostly in Motion and then edited in Final Cut Pro. I have some still frames in there as well but I'm using lots of keys to gradually make the animations bigger and I've also mixed in some green screen footage in there as well.
When I export it, only in a few places, it's adding one or two frames that aren't in the sequence. I'm not sure if the keying rate in the Export -using Quick Time conversion might have anything to do with it but I'd appreciate any help.
Ranya
