Playback lag 5400RPM or 7200RPM Hard Drives?
Joe Martino
on Mar 5, 2012 at 10:44:41 pm
When my sequences get fairly large at times I will get playback lag when viewing rendered work in full screen from my sequence. I had read that it can have something to do with hard drive spin speed and that 7200RPM is recommended for video work. Would 5400RPM drives create this type of issue? Or is this more so only going to be a problem when rendering?
My system right now is an iMac with 4GB ram. The playback lag doesn't happen all the time. At times final cut will get extremely slow also and i can't figure out the issue as the problem seems to happen at weird times. Any ideas? Does RPM speed affect it a lot?
Shane Ross
Re: Playback lag 5400RPM or 7200RPM Hard Drives?
on Mar 6, 2012 at 12:18:43 am
Yes, slow drives will effect playback. 5200 is too slow for video. And your system drive should NEVER be used to store media. Gotta get a firewire external that is at least 7200RPM.
Little Frog Post
Joseph Hung
on Mar 6, 2012 at 1:43:30 am
Shane is right. Also, eSATA, Firewire 800, or Thunderbolt if you have it on the iMac. Anything less would not help. A RAID enclosure would help with speed as well.
Twitter: @tulpapictures
Mac 2.66 GHz Quad Intel Xeon
OSX 10.6.8
ProAvio 8TB RAID 5 Dual Mini-SAS
Blackmagic Intensity Pro
ATI Radeon X1900
RocketRAID 4322 via dual MiniSAS
Panasonic Lumix GH2, Canon 5DMKII, 7D, Panasonic HVX200A, Panasonic DVX100A
© 2018 All Rights Reserved
