Conforming 60fps from T2i in Cinema Tools for Slow Motion
Zack Mulvaney
on Mar 4, 2012 at 2:39:32 am
From what I understand, the T2i shoots 60fps actually at 59.64. Accordingly, when I conform in cinema tools for slow motion, should I conform to 30 fps and 24 fps? Or should I conform to 29.97 fps and 23.97 fps?
Michael Gissing
Re: Conforming 60fps from T2i in Cinema Tools for Slow Motion
on Mar 4, 2012 at 3:12:50 am
You should conform to match the sequence you are editing in so no rendering and silky smooth slo mo.
Zack Mulvaney
on Mar 4, 2012 at 3:24:01 am
so let's say my sequence is set for 23.97 because the rest of my recordings are 24fps from my T2i (which would be 23.97). Then I should conform all my 60fps to 23.97?
Jeff Meyer
on Mar 4, 2012 at 5:44:02 am
Yup. As stated before, conform the footage to match the rate you're editing. If you shot everything else at 23.976 then conform your 59.94 to 23.976. You might make a duplicate copy of your clip before conforming, because it isn't a reversible process.
Zack Mulvaney
on Mar 4, 2012 at 6:10:22 am
Excellent. Thanks for the clarification, all.
Jason Brown
on Mar 4, 2012 at 3:21:07 am
FYI, I do this alot and found fcpx natively in timeline can conform 60 to 30 in real slowmo...it's not keyframeable (yet) but a step in a good direction.
