Final Cut Pro problem
Konstantinos Kitsos
on Mar 4, 2012 at 12:28:29 am
Hi
I am not an expert editor
I have a big problem with FCP and I do not know what to do:
Every time I am renter something it renters it momentarily and after goes back to "UN - RENDERED".
It is very disturbing.
I did not have this problem before - probably I touch something by mistake.
I have to bring my program back to normal.
I will be grateful for any sort of help guys.
Thank you very much.
Shane Ross
Re: Final Cut Pro problem
on Mar 4, 2012 at 2:05:46 am
What are the clip settings? What codec?
What are the sequence settings?
Shane
Little Frog Post
Konstantinos Kitsos
on Mar 4, 2012 at 3:16:28 am
Hi
Thank you for your answer
The setting were as usual.
It was set for Quick-Time.
I turned it HDV - the exact definition of the clips.
And again this problem.
It is nothing but 2 clips
I do not understand.
Someone told me that my computer does not have space.
But it is not possible: All my info - Everything is on an external drive.
I have nothing in the computer.
I do not know what to do - I am getting very nervous - Sorry for that.
