HDCAM SR 5.1 Surround Sound Question.
Reuben Fink
on Mar 3, 2012 at 6:15:48 am
On monday I'm taking a HDCAM SR tape in that needs dubbing. The client wants a prores version and a version on DVD for festival entry. It's supposed to have 5.1 surround. Normally I'm used to having all 6 stems named and ready for setup in compressor but this is a little different for me. I've never had the surround sound imbedded in the file I received. How do I know which channel is which since they are not labeled? I do not have a surround sound system to test it. Any ideas. I just want to be prepared before walking into the suite and burning HDCAM deck time.
OSX 10.6.4
Equipment: 2.8 ghz 8 core Intal Mac Pro, 20 gig of ram
Aps: CS5 Production Bundle, FCP Suite 2, Avid Media Composer
Juan Salvo
Re: HDCAM SR 5.1 Surround Sound Question.
on Mar 3, 2012 at 6:23:54 am
In qt pro you can set a trait for each channel. I.e. left, right, center, etc. however I always just export discreet tracks out of the movie and encode individually. I've had many sets of mislabeled audio channels so I always check the mapping on a surround sound system.
Michael Gissing
on Mar 3, 2012 at 10:39:44 pm
Unfortunately for you there is no one standard for track assignment. The tape should be labelled.
Likely possibilities are -
1=Left
2=Center
3=Right
4=LS
5=RS
6=Sub
or
1=Left
2=Right
3=LS
4=RS
5=Center
6=Sub
Have a look at the credits and see who did the sound post and email or ring them to have the track layout clarified
Reuben Fink
on Mar 4, 2012 at 8:29:06 am
Thanks for the advice. I'm in the process of trying to get ahold of the sound mixer. Should the dub include a stereo mix on tracks 7 & 8? I imagine if I try and mix down the 5.1 to stereo it wouldn't sound right would it?
OSX 10.6.4
Michael Gissing
on Mar 5, 2012 at 12:07:35 am
A proper stero fold down mix should also be on the tape. Again it should be clearly labelled. Stereo mix is most commonly tracks 1&2.
Do not just do a foldown yourself. There is a formula for foldowns but it should be done with proper monitoring and with the ability to do subtle trimming of surround and center channels.
