Working and exporting 25psf in final cut. Is it possible?
nadia iqbal
on Mar 2, 2012 at 7:12:54 pm
I've had quicktimes exported from a grade and they are Apple ProRes 422 HQ 25Psf. I would like to online them in Final Cut and then export the masters out as Apple ProRes 422 HQ 25Psf Quicktimes. This doesn't seem to be possible.
I was told that if I changed my Sequence and Capture Preset in the the Audio/Video Setting to PSF all the sequences that I create will become 25psf. There is no 25PSF option in the drop down menus for your Sequence and capture presets. If I change the Capture and Sequence Preset to Apple ProRes 422 HQ 25P (this is not ideal) and create a new sequence, the sequence is still Apple ProRes 422 HQ 25i.
If I load the 25psf quicktimes into a sequence and click YES when the FCP prompts me to change the sequence settings to match the clip then the resulting sequence is still 25i. I've been guaranteed that the quicktimes are 25psf and not 25i.
Can anyone tell me what settings I need to have to ensure I can work 25psf and export 25psf out again.
many thanks!
