Freeze Frame Hue Change on export
Derek Tow
on Feb 29, 2012 at 6:18:17 pm
Hey...
I have a clip that I have added a freeze frame to the end of and dissolved it out. Very standard fare. In the timeline, there is no issue as I scrub through the transition to freeze. But in the exported QT file, the hue of freeze frame lightens slightly and changes hue becoming a bit green and noticeably so.
Specs - FCP 6.0, MacPro 8 core
Timeline is ProRes 422 1920x1080.
Exporting QT file using same settings as in sequence.
Any thoughts?
Derek
Matt Lyon
Re: Freeze Frame Hue Change on export
on Feb 29, 2012 at 7:45:06 pm
Hi Derek, I've noticed this too and have found two workarounds:
when you export check the "recompress all frames" option
or
instead of using a freeze frame, razor blade the very last frame and copy-paste it as many times as you need. Then use a slug on the track above, with a fade up, to accomplish the dissolve.
hth,
Matt Lyon
Editor
Toronto
Edward Brosens
on Feb 29, 2012 at 9:00:44 pm
Hey Derek,
I think I know what you mean and it might be happening due to a difference in gamma settings.
What happens if you set the video processing settings like this (sequence settings)?
Derek Tow
on Feb 29, 2012 at 10:22:55 pm
Great ideas. I'll try these tomorrow. Stay tuned...
Derek Tow
on Mar 1, 2012 at 3:38:46 pm
Thanks Matt - the recompress all frame setting fixed it.
