missing log and capture viewer in Final Cut 6.06
Joe Cunningham
on Feb 28, 2012 at 2:31:54 am
For some reason, the viewer in my log and capture has disappeared, which means I cannot set in/out and disable audio capture from my Panasonic HDC-TM700 camera.
Jerry Hofmann
Re: missing log and capture viewer in Final Cut 6.06
on Feb 28, 2012 at 3:03:42 am
The window doesn't open or you can't see any video in it?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Joe Cunningham
on Feb 28, 2012 at 3:16:46 am
Thanks for your rapid response. When I open log and capture, all I see are the thumbnails and info columns, but the viewer is missing in action. I don't have a clue as to what I may have done to make it disappear, and have tried clicking on every possible button.
If it helps, I'm using a dual core intel Xeon MacPro with 4GB ram and OS 10.5.8
Shane Ross
on Feb 28, 2012 at 3:11:56 am
Log and Capture is for TAPE based cameras. This camera shoots TAPELESS. For that, you use Log and Transfer:
Tapeless Workflow for FCP 7 Tutorial
Shane
Little Frog Post
Joe Cunningham
on Feb 28, 2012 at 3:26:49 am
Ooops. sorry for the bogus info. I meant log and transfer. The problem just manifested last week. I rarely deal with tape anymore...thank God.
Shane Ross
on Feb 28, 2012 at 4:28:16 am
Trash your preferences
Shane
Little Frog Post
