XML from CS5.5 to FCP7 slow motion problems
valerio contessa
on Feb 27, 2012 at 7:00:58 pm
I made a montage with Premiere CS 5.5.
When completed, I had the need to change it in FCP7.
The original project in CS5.5 is a PAL DV widescreen and all clips are slowed down to 50%.
Then I exported to XML for changes in FCP7.
I opened FCP7 and I immediately noticed a problem, the cuts of clips on the timeline is accurate, but the speed is strangely changed, since all the clips that were to have slow motion at 50% now have the normal speed (100%).
Why not preserve FCP7 slow motion created in CS5.5?
Apart from that, the clips are cut points in and out wrong, as if he had changed the timecode.
How can I fix this?
Someone has already had a similar problem?
Thanks in advance for the help and sorry for my English.
