What Frame Size should I use for HD 4:3 aspect ratio?
Dave Chavinsky
on Feb 27, 2012 at 6:11:57 pm
1440x1080?
Its mostly photographs with some videos as well. I don't know how many pixels are in the pictures. I figured I'd make the project in HD and export to SD with whatever dimensions I want. (640x480) export.
so should I set it up at 1440x1080 with a Square Pixel Aspect Ratio?
Jerry Hofmann
Re: What Frame Size should I use for HD 4:3 aspect ratio?
on Feb 27, 2012 at 6:20:46 pm
Are the videos HD?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Shane Ross
on Feb 27, 2012 at 6:22:57 pm
There is no such thing as 4:3 HD. All HD is 16:9.
Shane
Little Frog Post
Steve Eisen
on Feb 27, 2012 at 7:25:22 pm
Dave
Set your sequence setting to ProRes 1920 x 1080.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
