Drop frames under text layer
Adriana Câmara
on Feb 27, 2012 at 6:05:57 pm
Hi!
I have just bought an iMac, 3.1GHz Quad-Core Intel Core i5, 2560 x 1440 resolution, 4GB (two 2GB) memory, 1TB hard drive, AMD Radeon HD 6970M with 1GB.
I have installed the Final Cut 7.0.3 in it.
I'm trying to put subtitles on a video, as simple text over a single video layer, without drop shadow or anything, and, every time the subtitle appears, there are dropframes on the image of the film, both during playback and on the exported video.
Have you heard about that problem?
Do you happen to know if there is a solution for that?
