Workflow tips needed!
lwazi mcongwane
on Feb 27, 2012 at 9:15:47 am
I'm editing a short film that was shot on 1080i HD with the use of a Panasonic AG-HMC154ER camera. My iMac has a 2.4 GHz Intel Core 2 Duo processor, with 2 GB of ram. I’m editing using FCP 7. The final product is for Standard DVD format, which will be projected onto a big wall. Can you please help me out with some workflow suggesting in order to achieve the best results?
Shane Ross
Re: Workflow tips needed!
on Feb 27, 2012 at 3:26:46 pm
THis is the workflow for importing tapeless media:
Tapeless Workflow for FCP 7 Tutorial
Edit ProRes 422, Export a self contained QT file, take into compressor and use a DVD Best quality preset. Take result into DVD SP for authoring.
Although the result will not be HD, it will be SD...projected onto a big wall.
Shane
Little Frog Post
