How set to start FCP7 from an External Drive on iMac
Milton Ginsberg
on Feb 24, 2012 at 5:06:59 pm
How can I set up an external hard drive for FCP7 and Snow Leopard
~ so I can update my computer to Mountain Lion (or even Dandelion)
~ and not lose capacity to edit complicated ongoing FCP7 projects.
Would just Snow Leopard and FCP7 alone on an external drive do it?
How can I best set up and copy across to external drive?
Dave LaRonde
Re: How set to start FCP7 from an External Drive on iMac
on Feb 24, 2012 at 5:11:00 pm
Why do you feel the need to change the OS right away?
Dave LaRonde
Sr. Promotion Producer
Milton Ginsberg
on Feb 24, 2012 at 5:17:55 pm
Want to try other editing software for new projects... Adobe, Avid, even FCPX, among other reasons.
Shane Ross
on Feb 24, 2012 at 5:59:17 pm
Avid Media Composer 6, Adobe CS5.5, work on Lion...the current OS. FCP 7 does too. The new OS that was just announced...don't expect the NLEs to work on those...or be qualified to work on those, right out of the gate.
Autodesk...not sure what OS that works best on, but I figure it falls on the same lines as the others, if it is kept up to date in a timely manner.
Jumping on the new OS right away, when you use professional applications of any kind, is NEVER wise.
Shane
Little Frog Post
David Roth Weiss
on Feb 25, 2012 at 5:49:32 pm
Check out my Cow tutorial: http://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1.
This tells you all you almost you need to know... Make sure to watch the video portion.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
http://www.ProMax.com
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
