Difference Between Mini dv, DV, HDV ?
vineet das
on Feb 23, 2012 at 7:56:48 am
What are the main Points of difference between Mini DV, DV & HDV?
How can i know that the shooted material on minidv, Dvcam tape is on SD or HDV format.
Vineet
(Trying to Rise)
Steve Eisen
Re: Difference Between Mini dv, DV, HDV ?
on Feb 23, 2012 at 1:28:51 pm
Have you Googled those terms? You should try it.
[vineet das] "How can i know that the shooted material on minidv, Dvcam tape is on SD or HDV format."
Quality of video and frame size could tell you.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Jerry Hofmann
on Feb 23, 2012 at 2:39:23 pm
mini DV and DV are basically the same format Standard definition video at 720X480 in frame size.
HDV is HD video and can be either 720p or 1080 in size. Either format should be displayed on a camera's on screen information during playback.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
