Offline to Online with XDCAM footage
Marcus Carter
on Feb 22, 2012 at 4:39:38 pm
G'day Folks,
Please could some bright person help me out here?
Here is the problem: Footage shot on XDCAM for a series. Footage captured at low-rez, as there is a LOT of footage!
Offline then completed, and ready to recapture for ONLINE. So we have a Project with 'Missing Footage' all over the show, and the need to capture the HD XDCAM clips off the Hard Drives. BUT, its all in MXF format! What now?
(As an aside, if we were working in P2, it would be cinch, just select all the clips and go Batch Capture, which in turn opens up 'Log + transfer' and re-ingests the Hi-rez clips needed for the online)
But the same doesn't seem to apply to XDCAM??
I am using the last version of FCP 7, on Snow Leopard, running on a 12-Core MacPro..
Any suggestions welcome...
Regards,
Marcus T
Marcus T
12 Core MacPro, 8Gb Memory, FCP 7.0.3
Victor Perez
Re: Offline to Online with XDCAM footage
on Feb 22, 2012 at 5:22:16 pm
If you have the original XDCam folder structure from the XDCam Discs on the drive. You can download the XDCam Transfer plugin to convert the files to Quicktime.
https://www.servicesplus.sel.sony.com/sony-software-model-PDZKP1.aspx
Not sure how it would work for XDCam EX.
Victor
http://www.editvictor.com
http://www.hbhm.tv
http://www.itvisus.com
Shane Ross
on Feb 22, 2012 at 5:24:47 pm
This is a workflow you really should have tested first. Because XDCAM doesn't import into FCP the same way P2 does. The workflow is not the same. You cannot BATCH CAPTURE like you do with P2. The only solution I have found is to import all of the footage at full resolution, and reconnect. Sorry, there really is no good offline/online workflow with XDCAM EX. XDCAM from disks is a bit different, as you have a deck and can use log and capture.
Shane
Little Frog Post
Michael Gissing
on Feb 22, 2012 at 10:56:44 pm
The cost in time trying to do an offline/ online workflow for a highly compressed format like XDCam must be far greater than the cost of extra hard drives to have done this in native codec. This is particularly the case if you used a different frame size in the low res files as any reframes or adjustments will have to be manually redone.
How much time was also spent converting from XDCam to the low res files? I see almost no reason to try an offline/ online with codecs like XDCam
Marcus Carter
on Feb 23, 2012 at 7:24:31 am
Yeah, wonderful thing that hindsight isn't it? Fortunately for me, i wasn't involved in the decision making, I would've gone with Panasonic...
Importing all the footage may be an option though..
Cheers..
Marcus T
Andy Mees
on Feb 23, 2012 at 11:04:01 am
Hi Marcus
Why not just finish the offline / online procedure the traditional way ie create an offline cut using Media Manager then recapture from the original source (using a deck and I/O device) at high res?
Or maybe check out Bouke Vahl's various XDCAM tools from VideoToolshed, which may offer the missing links for the workflow you're looking to establish.
Do agree with Shane, you really should have checked all this out before you jumped in :/
Given that your high res media is on a drive in MXF format (and assuming you no longer have the source discs) then you may want to start by rewrapping it in FCP compatible MOV containers (using XDCAM Transfer). Not ideal as you are rewrapping ALL the media rather than just the bits you used, but at least after that you should be able to use Bouke's FCPreconnect app to relink to the high res as needed.
Hope it helps
Andy
Marcus Carter
on Feb 24, 2012 at 1:15:26 pm
Thanks Andy, SONY really don't make the ride a smooth one, not like P2....
Regards,
Marcus
Marcus T
Alvin Santos
on Jun 19, 2012 at 12:01:24 pm
Sorry to butt in my question but I guess my problem is similar to this one.
We are doing a series using:
Canon 5d MarkIII - (they only sent us the h264 files and not the whole folder structure so i cannot log and
transfer)
Panasonic AF102 - no problem
Sony F3 - log and transfer's only option is xdcam
Now, we are discussing an offline/online workflow using prores proxy then upres to full res due to possible lack of space but when I think about it, there's no offline/online for xdcam and for my 5d footage.
any solutions?
Marcus Carter
on Jun 20, 2012 at 1:18:26 pm
Hey Alvin,
Here are some answers for you:
1. H.264 files off of a Canon 5D need to be converted to ProPes 422 in Compressor of MPEG Streamclip before you can edit with them..
2. Panasonic and FCP work together beautifully when going off/online..
3. Yes you're right XDCAM does not support the Offline/Online workflow in FCP. What we have done is to use SCRATCHLAB to generate proxy files for offline off the cards, then export an EDL, and recapture in Online Res.. complicated, but it saved the production...
Good luck..
marcus.
Marcus T
